Activity Forums Apple Final Cut Pro Project only visible in timeline and not events library
  • Project only visible in timeline and not events library
    Posted by Keelin Titzer on June 4, 2019 at 7:27 pm
    I would really appreciate some help with this. I imported a project from a FCP7 XML file to FCPX using SendtoX and then worked on the project for several days. A few days later when I opened the library, the project wasn’t visible in the event browser. I can only get the project to open by trashing preferences before opening Final Cut Pro. Then it shows up in the timeline, but it never shows up in the events browser. It says “Projects (1)” and then shows 0 projects. I have tried making a new project and copying all the files, but then the roles are lost and I spent a lot of time assigning roles to all the files in this project.
    Can anyone help me have the project show up normally? I searched but can’t find anyone with the same problem or a solution that’s worked.
    Keelin Titzer replied 7 years, 3 months ago 2 Members · 2 Replies
  • Joe Marler
    June 5, 2019 at 1:29 pm
    Within the library package, each project exists as a folder with the project name. Inside that folder is a CurrentVersion.fcpevent file which contains several SQLite database tables that hold all the edits for that project.
    My first recommendation is make a file-level backup of your current library in case subsequent steps adversely impact that. You can right-click and pick “duplicate”. Obviously this is easier with a “lean library” where media and cache are stored outside the library.
    Then in Finder you could do “show package contents”, open the event, and see if your project exists as a folder inside the event (or any other event in that library). If it’s not there that’s why it’s not shown in FCPX.
    If you have file-level backups such as Time Machine you could try restoring a previous version of the library, examine it and see at what point the project vanished.
    If you don’t have file-level backups, FCPX keeps auto backups of each library, by default located in /Movies/Final Cut Backups. I suggest first making a file-level backup of this entire folder to at least safeguard the current state.
    Then within FCPX you could do File>Open Library>From Backups, browse/load each library on the list and see if any contain the missing project. Alternatively at the Finder level you could sort the list of FCPX backups in date order, then do “show package contents” on each one and inspect which has the missing project. Once found you can load that library backup and drag/drop the project to your current library, or just use that library if it is sufficiently recent. Or you could save a project XML file and try to load that in your current library.
    The key is go slow and always have (at least one) file-level backup of the library you’re working with. In case something goes wrong you can revert to the previous state. You can rename the file-level library backup or use multiple alphanumeric Finder tags to remind yourself what state the library was in. E.g, “MyLibrary_BeforeLoadingProjXML”.
  • Keelin Titzer
    June 6, 2019 at 11:40 pm
    Hi Joe, thanks so much for your response.
    The project and its files are included in Finder when I click “show package contents.” I had already tried opening the backups in FCP and the only FCP backup that shows the project properly is the first backup. Since that’s too old to use, I will try saving the project as an XML file and opening it or making modifications in Finder to the library I duplicated. Thank you for your help! Hopefully something works.
