Activity Forums Adobe After Effects project on a wall effect
  • project on a wall effect
    Posted by Danonano on April 8, 2006 at 5:49 am
    I’m working on a project with a clip that involves a person walking down a tunnel. I hope to use AE to “project” another clip onto the walls of the tunnel. While I’m sure this is nothing unusual, I’m so new to AE that I’m not even sure what terms search for in the hopes of finding a tutorial. Can someone steer me in the right direction?
    thanks,
    Dan
    James Huenergardt replied 20 years, 5 months ago 3 Members · 2 Replies
  • Graham Quince
    April 9, 2006 at 7:26 am
    The trouble with AE is that it doesn’t do true 3D. As such, curved tunnel walls are hard to do. There are a couple of workarounds, but you’re probably looking at pre-comping the keyed greenscreen footage, followed by using Zaxwerks Invigorator and using that pre-comp as a reflection material. You’ll have to play around with this a lot to get the look right.
    If you check out the cow tutorials you’ll find a good tut on making a tunnel and also a number on how to use Zaxwerks.
    Graham
    https://www.qcit.co.uk – web design
    https://www.shiveringcactus.bravehost.com – Free FX for amateur films
  • James Huenergardt
    April 12, 2006 at 2:28 pm
    You could also try the CC Cylinder effect and rotate it. I know I’ve done a cylinder of just graphics I created in Photoshop with a person keyed out in the middle of the cylinder.
