Activity › Forums › Adobe Premiere Pro › Project Manager in PP CS6 not working.
  • Project Manager in PP CS6 not working.
    Posted by Jim Courtney on May 2, 2013 at 2:12 am
    So i want to export a big project from PPCS6, using Project Manager, to a bigger machine for finishing. I keep getting an error to save my project and try again. I have seen this same error message from other Adobe users, but no solution. And it never states what the problem is. Tried copying to a new sequence, no go. Plenty of hard drive space. I have all my work.comps, sequences ready to go, but can’t take it to the next step.
    Anyone get Project Manager to work?
    Jim Courtney replied 13 years, 5 months ago 2 Members · 4 Replies
  • Tim Kolb
    May 2, 2013 at 10:06 am
    we need more data. How many sequences? What type of data? Are you trimming or just gathering/moving…
    People use the project manager and it works (with format caveats), but without any info, the only question you asked that I can answer is:
    “Anyone get Project Manager to work?”
    Yes.
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Jim Courtney
    May 2, 2013 at 9:51 pm
    Hi Tim,
    Thanks for the quick reply. Information is crucial so here goes.
    The client handed off video, pictures and audio and I have three different video formats. The completed movie is 51 minutes, with one sequence, that includes two AE comps that match sequence settings.
    Sequence settings: (as recommended by a veteran video editor) HDV 720P. I have some HD footage at 1920×1080 and this particular setting was recommended.
    3 videos
    1920×1080
    720×480
    568×320(yep, I know…yuck!)
    Audio
    wav. 48000 Hz, 32 bit
    Pictures
    PSD 3264×2448
    jpg 378×553
    2 AE comps matching sequence settings.
    I chose to work in the 720P sequence setting in PP in order not to lose the native quality(yeah, that 320 isn’t great, but the client wanted it). I wanted to collect the files, the work, and everything associated with the project and transfer to the bigger machine to do the finishing(color grading, etc). Then send it to Media Encoder to make a 720×480 file for an NTSC Standard Def DVD. i didn’t want to compress in PP by sending that to a new sequence at 720×480, then sending that to Media Encoder, then Encore. Seemed like I might be adding more compression than I need and losing some quality. I did something like that in a similar project which took took long to collect the files, since I couldn’t get Project Manager to work. This current project has 149 items and would love PM to do the job for me.
    Jim
  • Tim Kolb
    May 2, 2013 at 10:29 pm
    So what exactly is happening? Files not trimming? Files not included?
    (The AE comps won’t be…you have to gather those up manually or render out and import the rendered clip, which will then be recognized bt the Project Manager.)
    TimK,
    Kolb Productions,
  • Jim Courtney
    May 2, 2013 at 10:58 pm
    The AE comps were rendered to QT mov files, no problem there. I chose the box, “Collect Files and Move to a New Location.” The total project size is 6.6 GB. When the Project Manager Progress goes through the “copying media,” it always ends up with the error message ” Premiere encountered an error and to try again.
    But wait. For some reason, when I tried it again for the 4th time, the files were copied. I didn’t do anything different. All I know it seemed to work. Two days of trying must of paid off!
    Thanks for taking the time, Tim
    Jim
