Activity › Forums › Adobe Premiere Pro › project manager collecting files that don’t exist in timeline
  • project manager collecting files that don’t exist in timeline
    Posted by Greg Janza on November 27, 2017 at 8:13 pm
    I’ve deleted this post because I was able to fix the issue by starting a new project and importing an xml of the final sequence into it.
    I Hate Television. I Hate It As Much As Peanuts. But I Can’t Stop Eating Peanuts.
    – Orson Welles
    Lee Davies replied 4 months, 3 weeks ago 4 Members · 4 Replies
  • Chris Wright
    November 27, 2017 at 11:03 pm
    here’s a bunch of project manager limitations from other posts from other people. You may find it interesting:
    Ok, we’ve got a few things here:
    I’ve found C300 footage to be super annoying to work with. For one thing, that camera does “clip spanning” which means while filming, once the file reaches ~4GB in size, it starts a new file. So for a 30 minute clip, you might have 6-7 MXF files, even though this is only “one take” or “one clip.”
    When you are project managing, say you pick 20 minutes of that 30 minute clip. Depending on where your in and our markers are, Premiere may pull ALL the clips because all the separate MXFs contain data from within your chosen timecode.
    This may also depend on how you brought your footage in. If you did it via the Media Browser, Premiere may consider it one clip and no matter where within the spanned clips your footage lies, it might bring over everything. If you brought your MXF files in individually and placed them together yourself on the sequence, Premiere might actually separate them correctly when you Media Manage.
    Finally, take a look at my thread here: Project Manager – Consolidate and Transcode problems
    I detail some issues specific to the Project Manager that will break some functionality without giving you and sort of error or message, though this pertains mainly to using Consolidate and Transcode, not the “Copy files to new destination” function. I admit I have not used that as much as Consolidate.
    A while back I had several issues with clips not trimming properly during the Consolidate and Transcode process. I reached out to Adobe support and was given this fairly comprehensive list of when and why clips will fail. For some reason, this list is not posted publicly anywhere. I’ve copied it in it’s entirely below. I’ve bolded several line items I feel are fairly important. There are now essential features in Premiere that I skip using (such as the Master Clip Effect layer) since it breaks the archive process.
    These issues affect all versions of Premiere, including the current CC2017 version – 11.1.2 (22)
    Hopefully this will help some people with project management.
    If any one of the 4 major video parameters (frame size, frame rate, fielding, PAR) do not match or are not supported by Preset/codec, then entire clip will copy. If the clip has multiple stereo channels of audio. These can only transcode to QuickTime, all other formats(e.g.: DNxHD) will fail and copy, since the other exporters do not support multi-stereo (QuickTime is the only exporter that currently supports that and only with uncompressed audio) Time remapping is not supported. Will copy entire clip without warning.
    There area number of formats/presets that are not supported for transcode (e.g. mostly still formats)
    Merged Clips are not supported. Copy of folder structures (e.g.: P2, AVCHD, etc.) is not supported. Depending on format, some files may be left out or other issues. Master Clip Effects are not supported, and will be copied without no warning. This includes all the formats that now have source settings as Master Clip Effects (e.g.: R3D, ARRI, etc.) Audio only files If used in a merged clip. Unused merged clips will also copy. Render and Replace files, even if unused Clips with dual mono (2 mono) will copy, although they may also transcode (this is a known bug), but the project will always link to the copied clip and not the transcoded clip (using up even more space)
    Clips with single mono audio will also fail to transcode. Modify > Audio Channel changes may also result in failure to transcode.
  • Greg Janza
    November 28, 2017 at 1:23 am
    Chris, thanks for the detailed info on troubleshooting Project Manager. It is the single most frustrating feature within the program for me.
    In the days of Avid, collecting a project was a very straightforward and simple affair. But with Premiere the variables are many and overall the interface just isn’t what it needs to be.
    So while adding VR and 360 certainly helps from a marketing perspective I sure would love to see something as unsexy as the project manager just work.
    – Orson Welles
  • Brent Marginet
    November 28, 2017 at 4:03 pm
    [Chris Wright] “I’ve found C300 footage to be super annoying to work with. For one thing, that camera does “clip spanning” which means while filming, once the file reaches ~4GB in size, it starts a new file. So for a 30 minute clip, you might have 6-7 MXF files, even though this is only “one take” or “one clip.””
    The Canon C300 and a few other models do, do clip spanning but you can and should always offload the cards with Canon’s XF Utility.
    XF Utility allows you to combine Spanned Clips into one single Clip and also extracts the media off the Cards Properly.
    \”MY MEDIA/PROJECT MOTTO: If you think three copies of your Media or Projects are enough. Take a moment to place a value on them and then maybe add two more.
    Hard Drives are now stupidly cheap. A RE-SHOOT AND YOUR TIME AREN\’T.\”
  • Lee Davies
    May 6, 2026 at 7:37 pm
    This is one of the traps with treating Project Manager as a perfect “what did I use?” report.
    It is sequence-based, but the media copy/consolidate result can still be affected by how the footage was imported and what kind of media it is. Spanned camera media, long-GOP codecs, merged clips, speed changes, master clip effects, plugins, and transcode limitations can all push Premiere toward copying more than you expected instead of making a neat trimmed package.
    So I would use Project Manager for what it is good at: making a working archive/handoff folder for a selected sequence. I would not use the output as proof that everything outside the package is safe to delete.
    Safer archive pass:
    1. Duplicate the project.
    2. Import/copy only the final sequence into a clean project if the source project is messy.
    3. Run Project Manager or a dedicated collect tool.
    4. Open the collected project with the original media offline/disconnected.
    5. Watch for missing media, AE links, fonts, plugins, and relink prompts.
    6. Keep the original camera media until the archive has been verified and the job is truly closed.
    Project Manager can save space, but it is not a storage audit layer.
