Activity › Forums › Adobe After Effects › Project ideas for a newbie
  • Project ideas for a newbie
    Posted by Maktoom Ahmad on February 21, 2014 at 9:37 am
    HI,
    I am new on the creativecow forum and not sure why i am new cause i should have been here ages ago. Anyway, I know softwares like After Effects and Cinema4D but only the basics. I think one of the ways to learn more is to do some projects. However, the problem is i don’t know what sort of projects i can do and am not able to come up with a idea.
    Please help
    Regards,
    Maktoom
    Anders Hattne replied 12 years, 7 months ago 3 Members · 3 Replies
  • John Cuevas
    February 21, 2014 at 3:48 pm
    There are some great free resources for learning AE and C4D. If you are just starting, I would suggest beginning here: Getting started with After Effects (CS4, CS5, CS5.5, CS6, & CC)
    Once you move through that, I think some of the most creative and fun tutorials, that use a wide range of techniques can be found at VideoCopilot(mostly AE), Greyscalegorrila(combines C4D and AE) and Motionworks(C4D and AE).
    There’s a ton of other great sites out there too, do a search for C4D or After Effects tutorials and you’ll find them.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Maktoom Ahmad
    February 23, 2014 at 8:27 am
    I have watched most of tutorials you mentioned above.However, now i want to do projects which i can then use to show my skills but i dont know what sort of projects i could work on or things i could create.
    Can anyone help me with that?
    Regards,
    Maktoom
  • Anders Hattne
    February 24, 2014 at 9:31 am
    If you work with Cinema 4d you might be familiar with Greyscale gorilla. He started these 5 second proyects which is a very good idea for preactise and …portfolio filler!
    Why not look at the past proposed themes and do your own projects, that way you have a starting point and have to use your imagination too. It’s better than just setting out to imitate somebody else’s project.
    http://www.ardillamedia.com
