Activity Forums Avid Media Composer project frame rate for HD offline from SD downconvert
  • project frame rate for HD offline from SD downconvert
    Posted by Deborah Liekkio on December 24, 2007 at 9:29 pm
    I’ve been given a Digi downconvert from a D5 Master. I need to do an offline on my avid then output a list for the post house to do the HD online, which I’ve been told is 23.97. When I create my project to digitize the downconvert what frame rate should I choose? Can I digitize at 30 frames then set the EDL for 23.97? Any help with the proper workflow would be greatly appreciated.
    Debbie
    Michael Phillips replied 18 years, 8 months ago 2 Members · 1 Reply
  • Michael Phillips
    December 25, 2007 at 3:52 pm
    If it’s nothing but straight cuts and dissolves and you are not doing your online on an Avid product (Media Composer Adrenaline, Symphony Nitris, DS Nitris) then working in 29.97 and delivering a matchback EDL to 23.976 is OK, not great. You need to remember to be in a matchback project and know that your edit points can be +/- 1 frame at any one point.
    Creating a 23.976 project will allow for more flexibility as well as accuracy in the final conform. You can still create an EDL but without the +/-1 frame adjustments but if conforming on an Avid system you can hand over the bin with the sequence or an AA sequence (if going to DS) and have conform of layers, effects, titles, etc. Audio will be easier to deal with as well if going through Pro Tools or you want to create a temp track for the conform.
    Michael
