Activity › Forums › Adobe After Effects › Project Crisis: Playback Crawls on Large Layer Opacity Fades (M1, 8GB, Ext Drive
  • Walter Soyka
    January 27, 2026 at 1:06 pm
    The memory requirements for this project are huge. Ae will need 1.4 GB of RAM for each frame of each layer, just to hold the images.
    Can you reduce those source images in size at all? Or can your other app output them as vector graphics instead of PNGs? Or break them into pieces and tile them if you don’t need to see the whole thing on-screen at the same time?
    Otherwise, you should probably turn off multi-processing, or try working and previewing at quarter-resolution (or lower) — but even in these cases, your renders will take quite a long time.
