Activity Forums Adobe Premiere Pro Project and data linking nightmare
  • Project and data linking nightmare
    Posted by Peter Dexter on May 24, 2012 at 7:02 pm
    Hi
    I use a PC, I have been working on a project for some while now, it has some 3500 files located on a drive. The scratch and all such were set up on different drives to the data and op sys etc. Working fine and dandy. My hard drive with the data went west. It was drive no J:
    I kept two back ups in case of such an eventuality. These were identical folder structure and file naming to the broken drives structure and naming. Mirror copies.
    I installed the back up drive and re named it to J. I have done this before in an expirment and it worked just fine. Premiere never knew the difference. All opened ok.
    However today (when I really need it), premier is asking for the location of all of the files. Of course I have to select skip and then skip all due to the large number of them. the project opens but all media is offline. The sequences and files have all the correct names and are in the correct order in the respective bins but I cannot link the project to the drive material.
    Is there a way to rectify this? Has anyone encountered the same issue and if so is there a work around/solution?
    Please say “yes there is an easy remedy” somebody please 🙂
    Thanks in advance for any assistance.
    Cheers
    Peter
    We spent all the budget on doughnuts and now we have no money to make our film.
    Peter Dexter replied 14 years, 3 months ago 1 Member · 1 Reply
  • Peter Dexter
    May 24, 2012 at 10:32 pm
    Hi
    Phew. In case anybody read my post and wondered. There is a simple solution. Just point to the first file Premier asks for and lo and behold it locates the rest.
    I did not have do that when I tested it before. It just opened. Must be due to the re formating of drives and new Windows installation or some such.
    Anyway thanks in case you droped by to help.
    Peter
