Activity › Forums › Adobe After Effects › Project AE won’t open
  • Project AE won’t open
    Posted by Guy Voisin on January 9, 2009 at 4:49 pm
    Hi
    My project AE won’t open after I changed the name, it was called Destination 2 and I took off the “2”. Now it will no longer open.Any help appreciated.
    Guy
    Guy Voisin replied 17 years, 8 months ago 2 Members · 2 Replies
  • Kevin Camp
    January 9, 2009 at 6:15 pm
    just changing the file name shouldn’t effect the project opening… did you remove or modify the tag (file extension)… it should be .aep
    if the tag isn’t the problem, then try creating a new project and import the old project into it.
    and just to make sure, you are not trying to open the project in an older version of ae, correct? ae projects are not backwards compatible so, for example, a cs4 project will not open in cs3 regardless of the name…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Guy Voisin
    January 9, 2009 at 6:54 pm
    Hi Kevin,
    Just tried what you suggested and I get an error message 33::4.
    The .aep is there
    Can’t open in other project
    The same AE that it was built in
    If you think of anything else thanks in advance…
    Guy
    GuyNeb
