Activity Forums Live Events & Streaming project 3 separate videos synchronized
  • project 3 separate videos synchronized
    Posted by Susie Su on August 4, 2018 at 7:54 pm
    For an art installation I need to set up a synchronized projection of 3 separate videos:
    hardware
    – 1 PC with Windows 7
    – NVIDIA GeForce GTX 980 with 4 simultaneous outputs
    – 3 projectors 1920 x 1080 (I don’t know the type yet)
    – if necessary: 1 monitor 1920 x 1080 for user interface
    video files
    – 3 separate video files
    – resolution 1920 x 1080
    – all 3 videos have exactly the same length: 18 minutes
    – one video has sound, the two other videos are without sound
    I need to play the videos synchronized with one player software which controls all 3 videos. The videos will be looped over 8 hours. They need to stay in exact sync frame by frame even after 8 hours.
    The presentation is for a major art event with a large number of visitors. Therefore I am looking for a very stable solution. However the budget for the software is limited (not more then $750, less is better).
    After some research I see the following possibilities:
    1. I could combine all 3 videos in one large video with a width of 3 x 1920 = 5760 and a height of 1080. Then I can play one single video.
    – What codec and what player software could be used in this case?
    2. I could use a software which can show the 3 separate videos in sync.
    – What (reasonable priced) player software can do the task to show the videos in sync even after hours?
    Alan Langdon replied 7 years, 8 months ago 4 Members · 5 Replies
  • Thomas Leong
    August 6, 2018 at 7:01 pm
    [Susie Su] “1. I could combine all 3 videos in one large video with a width of 3 x 1920 = 5760 and a height of 1080. Then I can play one single video.
    – What codec and what player software could be used in this case?”
    A: With a Matrox TripleHeadToGo or a made-in-China equivalent, not sure what codec – try h264, but better would be HAP (under a .mov wrapper) which pushes the decompression and playback workload to the graphics card. Software would be Quicktime or VLC. My guess is you would need at least an i7 processor to handle playback of 3×1920 resolution, and SSD or M.2 ‘disk’.
    [Susie Su] “2. I could use a software which can show the 3 separate videos in sync.
    – What (reasonable priced) player software can do the task to show the videos in sync even after hours?”
    A: Try MadMapper or Mapio2Pro both priced at about euro350. Resolume or Resolume Arena could do it as well, I guess, but I’m not familiar with Resolume.
    Framesynced exactly when looped may be asking too much of these software at those prices. A frame or two out of sync after a loop or two is more likely, and chances are it would not be noticeable to the layman not looking for it with an eagle eye.
  • Susie Su
    August 6, 2018 at 11:16 pm
    Thanks for the answers.
    regarding the Matrox TripleHeadToGo: Why would I need the Matrox TripleHeadToGo? I have a NVIDIA GeForce GTX 980 with 4 simultaneous outputs with NVIDIA surround possibility. Isn’t this sufficient?
  • Thomas Leong
    August 7, 2018 at 4:48 pm
    Apologies, missed that.
    Not familiar with nVidia, more familiar with AMD.
    Yes, if the nVidia can be setup to ‘merge 3 displays as one big one’, you do not need the Matrox. The only question remaining is whether the rest of the system can play the one big file without hiccups. Only a test will tell.
  • Todd Perchert
    August 16, 2018 at 3:20 pm
    Chances are you won’t be able to play that large of a file without some problems. You will need to render out to a fraction of the size and scale it up. mp4 is a good option – small file size, still looks good.
    But you definitely need to test out your hardware/software to make sure you can do what you want to do.
    TC
  • Alan Langdon
    October 5, 2018 at 12:41 pm
    I have the exact same issue, but with different equipment:
    I need to project 3 distinct images (1080p ideally, 720 is ok) using 3 separate displays/projectors, just like the original question in this thread. They need to be in synch also, for art exhibit.
    My equipment is two mac minis: i5 2.5 ghz 8gb ram 1TB SATA drive (2014 models, I believe),
    so each has built in capability to output 2 displays.
    question 1: Can I connect both macs in network and have one output 2 displays and the other 1 display? If so, how would I get them to synchronize? VLC? Resolume?
    question 2: Would it be more feasable to get some hardware that allows 1 macmini to output 3 displays?
