Activity Forums Adobe Premiere Pro Proj files work fine one day, next day they are corrupted???
  • Proj files work fine one day, next day they are corrupted???
    Posted by Eric Hunter on October 3, 2013 at 2:59 pm
    I am working on a MacBook Pro, using the CS6 suite. All media files and proj files are stored on a G RAID 4TB.
    Within the last month, certain files have been unable to copy from the G RAID onto a backup drive. It copies the majority of the file and then stops and gives me a “unable to read or locate file” error. Now this has started happening to my proj files as well.
    One day I am working on an edit, everything is normal. Next day, I open the project and get a “file may be corrupt or contain out dated elements” message. I try to copy the proj file to another drive and I get the “unable to read or locate file” message. This is becoming worse and worse, as it has happened to three proj files now.
    Finding any information on G RAID issues has been nearly impossible. I have tried clearing permissions, repairing the disk, and importing the damaged proj file into a working proj file. None work. Any ideas?
    Walter Soyka replied 12 years, 11 months ago 3 Members · 2 Replies
  • Kevin Monahan
    October 3, 2013 at 4:31 pm
    Hi Eric,
    Where do you store the project file, on the boot drive or the media drive?
    Kevin
    Kevin Monahan
    Social Support Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Walter Soyka
    October 3, 2013 at 5:53 pm
    [Eric Hunter] “Within the last month, certain files have been unable to copy from the G RAID onto a backup drive. It copies the majority of the file and then stops and gives me a “unable to read or locate file” error. Now this has started happening to my proj files as well.”
    That sounds like you have either a problem with the filesystem or with the physical disks. Since you’re on a Mac, I’d suggest you try DiskWarrior [link].
    For the projects, you may be able to find a working autosave file.
    Walter Soyka
