Activity Forums Apple Final Cut Pro Legacy progressive vs interlaced output question
  • progressive vs interlaced output question
    Posted by Kris Mehaffey on April 17, 2007 at 5:21 am
    i’m creating content to be burned onto DVD using DVD Studio. I’ve gone through and deinterlaced and massaged the footage and gotten rid of most of the jaggies and other unattractive aspects of my DV source footage. i know the steps of the whole output process and have done several projects already in this fashion, but i’ve always wondered which option i should choose when running the footage through Compressor. The footage is for wedding DVDs, non-commercial/non-broadcast use.
    so, my question: should i choose “interlaced” or “progressive” when i output these vids?
    thanks in advance.
    Kris Mehaffey replied 19 years, 4 months ago 2 Members · 5 Replies
  • David Battistella
    April 18, 2007 at 1:24 pm
    If you have de-interlaced the footage then this means that you are only providing half of the video signal. 1 field. so there is no point in using a progressive output.
    If you capture the DV firewire as a Progressive image and edit that image natively then you might want to output a progressive DVD.
    the safest thing to do is select same as source or run a few tests on short passages and compare the compression on the tv screen. Make a slate over each one so that you know what you are watching.
    David
    Peace and Love 🙂
  • Kris Mehaffey
    April 18, 2007 at 6:48 pm
    thanks for the advice, David.
    i’ve duplicated my footage, deinterlaced both (one odd, one even), laid one over the other and brought down the opacity of the upper-deinterlaced track. then nested that sequence into another to apply over-all filters like a widescreen matte, etc.
  • Kris Mehaffey
  • David Battistella
    April 18, 2007 at 6:55 pm
    Why would you do this?
    Where did you get advice to do this?
    David
    Peace and Love 🙂
  • Kris Mehaffey
    April 18, 2007 at 8:09 pm
    a deinterlacing “try these tricks” tutorial on Ken Stone’s Final Cut site.
