Activity Forums VEGAS Pro progressive video using a lower field first setting?
  • progressive video using a lower field first setting?
    Posted by Travis Taylor on August 28, 2009 at 3:56 pm
    Hi, I edit in Vegas, using both progressive video clips and interlaced video clips. In order to avoid combing artifacts with the interlaced clips, I have been setting the field order to Lower field first. There doesn’t seem to be any noticeable degradation in the progressive video clips, but I just am not sure. My question is, will the use of a lower field first setting affect (and lower the quality of) the progressive video clips?
    Nhat Nguyen replied 17 years ago 3 Members · 2 Replies
  • Jeremy Rasnic
    August 28, 2009 at 7:02 pm
    If you tell it to render with LFF instead of progressive, it will override the default settings of the file itself and rid the event of half of its temporal resolution. You are basically throwing away half the fields of the images that make up the event.
    j razz
    https://www.jrazzcreations.com
  • Nhat Nguyen
    August 31, 2009 at 7:54 pm
    Hi Jeremy Rasnic,
    I ofently run into the same situation using interlaced and Progressive videos on my time line So what setting i should choose
    in Vegas’s Properties?
    My name is Max and i’m very new to the Forum.
    Sorry for barging in like this.
