Activity › Forums › Maxon Cinema 4D › Progressive Morph
  • Progressive Morph
    Posted by André Marques on February 10, 2011 at 5:16 pm
    Hello guys!
    I’m trying to do an eye blink and the thing is that if i do a straight morph from the open position to the
    closed position, the geometry simply overpass the eye geometry.
    So…what is the way to do a progressive morph like in 3DS MAX, mixing all the inbetween poses??
    i can do all the inbetween poses and then animate then individual. but thats not what i want
    how can i get then together in a single slider?
    thanks
    Adam Trachtenberg replied 15 years, 7 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    February 10, 2011 at 6:36 pm
    Have you tried using a rotational morph? That can eliminate the need to create the in-between poses altogether.
  • André Marques
    February 11, 2011 at 11:31 am
    I guess that doesn’t work like i want to,
    because im just trying to move points, not rotating objects.
    I need a way to mix just a single inbetween pose when the slider is at 50% (going from closed pose to open pose)
    I appreciate your help
    André
  • Adam Trachtenberg
    February 11, 2011 at 2:32 pm
    rotational morphs work with points, but they can be a bit tricky. You can do what you want with a little bit of Xpresso. Basically what you do is add user data to your eyelid object in the form of a slider and then connect the slider to rangemappers which drive the different poses.
    Here’s a quick example: 1629_poseslider.c4d.zip
