Activity Forums Adobe Premiere Pro Progressive, interlaced? Video noise in all clips
  • Progressive, interlaced? Video noise in all clips
    Posted by Jimena Mora on May 27, 2015 at 4:10 pm
    Hello
    Im editing a video and all my clips have line like noise. I tried changing the sequence settings, thinking that the progressive or interlaced might be the problem, but couldnt find a solution.
    The material was recorded with an Inspire 1 drone, at 59.94 fps. And my sequence has the following settings:
    Editing Mode: DSLR
    Timebase: 59.94
    Frame Size: 1920×1080 16:9
    Square Pixels (1.0)
    No fields (progressive scan)
    Display format: 60fps drop frame timecode
    Are my settings wrong?
    Thank you in advance
    Vince Becquiot replied 11 years, 4 months ago 2 Members · 3 Replies
  • Vince Becquiot
    May 27, 2015 at 6:44 pm
    Hi Jimena,
    Could you post a screenshot? A common issue with drones is shadows from the blades onto the lens causing a hum like overlay, is it not in the original footage?
    As long as the footage was shot progressive, I can’t think of any other issues causing it.
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
  • Jimena Mora
    May 27, 2015 at 7:25 pm
    Hi Vince thank you for your reply.
    The original footage doesnt have the noise. I cannot send a screenshot because when paused you will not notice it.
    If it was shot in progressive what sequence settings should I use?
    Thank you again
  • Vince Becquiot
    May 28, 2015 at 7:06 pm
    Ii really depends on the original footage. If you drag it into the new sequence icon on the project panel, you should get the correct settings.
    Vince Becquiot
