Activity › Forums › Apple Final Cut Pro Legacy › Progressive h.64 file to dv
  • Progressive h.64 file to dv
    Posted by Peter Dewit on August 30, 2007 at 2:58 pm
    I have a h.264 file that I need to convert to DV. The file was encoded progressively. So I try to covert ti(either via Streamclip, media Manager or jsut dropping it on a Dv timeline) and the footage comes out with what looks like a frame mismatch prolem. On most moving shots it has a bad stuttering flickery to all movement. I’m guessing that when it was interlaced the fields weren’t put together properly.
    I do not have the original media or I’d be working from that. any ideas how i could convert this footage better? I tried shift fields on both settings butit doesn’t seem to make any difference
    Also I guess I should note the original file is 640×480 so it does not fit the DV frame perfectly. the origianl was a wbe file so it wasn’t framed for TV safes either. As a result I’ve been returning the scale to 100 and accepting a small black border around the video rather than cutting off the titling.
    Tom Brooks replied 19 years ago 3 Members · 2 Replies
  • Chris Borjis
    August 30, 2007 at 3:24 pm
    at that point I’d use compressor and set the field order there.
  • Tom Brooks
    August 30, 2007 at 3:35 pm
    The frame rate of the orig might be more important to the result than the fact that it was progressive. Was it 29.97 or something else?
