Activity › Forums › Apple Final Cut Pro Legacy › Progressive Frame QT Conversion Output
  • Progressive Frame QT Conversion Output
    Posted by Fargoross on November 30, 2006 at 3:27 pm
    I’m creating many projects that need approval quicktimes send out periodically.
    I’m editing in NTSC 8-bit uncompressed SD using FCP 5.12, my field dominance is set to lower.
    My footage looks fine on the broadcast monitor. But when I export the sequence to post a quicktime to our FTP
    site, much of the video shows it’s interlacing.
    I have Flip4Mac, and that has a setting that allows me to export as progressive frames and not fields, but that is
    only in the WMV format.
    So far the only way I can figure out to export a Progressive Frame QT, is to change the field dominance to none in the sequence settings, which then requires me to re-render the sequence (Waste a lot of time) before I can send out a QT.
    Is there an easier way to do this?
    Ross Hendrickson, Editor
    Video Arts Studios
    Jeremy Garchow replied 19 years, 10 months ago 2 Members · 5 Replies
  • Jeremy Garchow
    November 30, 2006 at 4:27 pm
    You are using just the quicktime conversion to export? Try exporting a reference movie and bringing that into compressor and do you deinterlacing/encoding there.
    Jeremy
  • Fargoross
    November 30, 2006 at 7:40 pm
    Yes, I have been looking for progressive rendered quicktimes through the quicktime converstion export.
    Really, the easiest way to go from a lower field dominant timeline to a progressive frame quicktime export.
    I would hope that I could do this right from inside FCP and not have to get compressor involved (yet, thank for the tip of course).
    Ross
  • Jeremy Garchow
    November 30, 2006 at 8:11 pm
    You can set yourself up a preset in compressor and it’s almost just as easy and you can do multiple compressions at a time, or keep editing while your export movie compresses.
    Don’t be scared of it, it’s really useful and will give you tons of more useful options.
    Jeremy
  • Fargoross
    November 30, 2006 at 8:33 pm
    Good point about the process running in the background. I’ll give it a run.
    Thanks Jeremy, much appreciated.
    Ross
  • Jeremy Garchow
    November 30, 2006 at 8:37 pm
    No problem, if you have any further question regarding compressor, please don’t hesitate to post back.
