Activity › Forums › Apple Final Cut Pro Legacy › Professional way of adding 3:2 pulldown to 24p
Daniel Stone replied 9 years, 5 months ago 8 Members · 23 Replies
Bruno Miguel
March 15, 2017 at 12:16 amUeah Shane, we are monitoring in a sony luma series broadcast via blackmagic output. In premiere you can also choose to display both fields in order to see 3:2 happening.
Shane Ross
March 15, 2017 at 12:18 amAh..ok. Well, why not post this in the Adobe forums?
https://forums.creativecow.net/adobepremierepro
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Daniel Stone
March 15, 2017 at 3:22 amAlways add 3:2 pulldown in the export menu. You just have to select 29.97, upper/lower frames, and pixel aspect. Premiere does a really good job. If you don’t have a broadcast monitor, you can step through and count frames. If done properly, you should always advance forward with the exception of the duplicated frames.
