Activity › Forums › Apple Final Cut Pro Legacy › Production Monitor or Plasma
  • Sean Lacanita
    April 27, 2006 at 6:16 pm
    My understanding is that a 20″ production monitor should not be on a workstation desk — it needs to be placed farther back for proper viewing.
    For a desk, a 14″ production monitor is the correct size…so this would be a consideration.
  • Sean Lander
    April 27, 2006 at 9:33 pm
    Well I just finished a series for the Discovery Channel that was graded and on-lined on a 20″ sitting right next to the cinema displays.
    No problems what so ever, and the larger image is a benefit. You’ll find a 14 or 15 is significantly cheaper, but if you can afford it go for
    a 17″ at least, remembering that if your like us here in Oz almost everything nowadays is edited in 16:9 so you are effectively reducing the
    image size on the CRT by a fair percentage.
    My 2 cents.
  • Ken Summerall
    April 28, 2006 at 12:33 pm
    [Sean Lander] “Well I just finished a series for the Discovery Channel that was graded and on-lined on a 20″ sitting right next to the cinema displays.
    image size on the CRT by a fair percentage.”
    Thanks Sean, I had thought about a 14″, but having used one of those in a broadcast situation with it right in front of me I felt that it was just too small and one of the coporate edit suites that I frequent has one of these 20″ bad boys in both of their suites and they are easy to see from the desk or accross the room. I see this as a benefit.
    As for 16:9, I am afraid that the majority of our work will be 4:3 for the distant future. In education we tend to lag behind the rest of the world for a bit. Sad but true.
    Thanks again
    Ken Summerall
Page 2 of 2
