Activity › Forums › Apple Final Cut Pro Legacy › Production Monitor or Plasma
  • Production Monitor or Plasma
    Posted by Ken Summerall on April 26, 2006 at 12:34 pm
    OK, I do production work for a small university. most of our work is creating Video pieces for online learning and converting older classes shot on 3/4″ and DVCAM to DVD. Here’s my question. We are editing on FCP 5.04 and at this point just have a really cheap Panasonic TV/VCR combo unit to use as a monitor. We have a 20″ Apple display on the G5’s. We are trying to convince the powers that be that we need 2 productions monitors to enable us to do a little color correction and just to make sure that everything looks good. I like the 20″ Sony monitor that B&H has for about 2K but I noticed that they also have a Panasonic Professional 32″ and 37″ Plasma display for about the same money. I know that the Sony CRT is probably ideal but the plasma is good for the “WOW” factor. Which one should I get? Are the colors on the plasma going to be true enough to correct with? Help!
    Ken Summerall
    Ken Summerall replied 20 years, 5 months ago 7 Members · 13 Replies
  • 13 Replies
  • Marc Rolph
    April 26, 2006 at 1:27 pm
    As somebody who just purchased and mounted a Panasonic Plasma in my editing suite…I’d have to say it’s not made for editing. There are all kinds of reasons, but I’d say mostly it’s not always color accurate and plasma’s do suffer from burn in, which could be an issue while editing. Get the Sony CRT while you can, you won’t be dissapointed. Then, when money is available, add the Plasma for other people. Think of yourself and your work first.
    Marc Rolph
    Producer/Director
    Mississippi State University
    “If you chase two rabbits, both will get away.”
  • Sean Lander
    April 26, 2006 at 1:40 pm
    If you ever deliver product that will be viewed on a CRT then I think you must have a CRT as a production monitor.
    Too many times I’ve seen field reversals go to air because the editor didn’t have an interlaced production monitor.
    This happens especially when your mixing DV footage (Lower) WIth Uncompressed (Upper) in PAL.
    Plus CRTs just look so much better.
  • Chris Borjis
    April 26, 2006 at 4:15 pm
    I think at this moment if your doing SD and HD you should have both a CRT & some sort of flatscreen. Viewers in the home have both, with flatscreens growing in numbers every year.
    But its really important to have a calibrated professional grade CRT and that cannot be emphasized enough. At least until flatscreen quality matures to the point it equals or surpasses crt’s for performance.
  • Tom Ackroyd
    April 26, 2006 at 9:43 pm
    Sean – plasmas and LCDs display interlaced video just as CRTs do, but *only* if they are TVs, fed with video, not computer monitors fed with, er, not-video.
    So field reversals should be picked up so long as viewing is done on a (ie any flavour of) TV, not a computer display.
    Also, you say
    “If you ever deliver product that will be viewed on a CRT then I think you must have a CRT as a production monitor.”
    Does this mean if you know the material will *never* be viewed on a CRT that you should *not* use one?! Discuss!!
    Tom Ackroyd
  • Sean Lacanita
    April 26, 2006 at 10:40 pm
    Also, Sony has a line of LCD production monitors (LMD-) which they claim are replacement for their CRT production monitor line.
    Is this still controversial?
  • Chris Borjis
    April 26, 2006 at 10:55 pm
    I’d have to say it is. Field order issues can’t be solved or seen on flat panels.
    I am so very depressed every time I see a commercial or some broadcast show that had reversed field order issues.
    I also check every DVD I ever make for that as well. Sometimes the fields will reverse because of buggy software (like compressor2 used to do)
  • Walter Biscardi
    April 26, 2006 at 11:59 pm
    [Ken Summerall] “I know that the Sony CRT is probably ideal but the plasma is good for the “WOW” factor. Which one should I get? Are the colors on the plasma going to be true enough to correct with? Help!”
    I have both a Sony PVM20L5/1 Multi-Format CRT and a Panasonic 50″ professional plasma in our primary suite, along with a 14″ Sony CRT in our second suite. The plasma is calibrated almost identically to the Sony and we now use that monitor solely for client review and final review of any project. The Sony is used for Color Correction as it does feature SMPTE-C Phosphors, but the Panasonic is so true to that one, that I feel completely confident letting broadcast shows be reviewed on that screen.
    If I had the choice of one or the other, it would be the CRT, but it would ONLY be a true Multiformat SD/HD CRT monitor with SMPTE-C Phosphors. The plasma is an outstanding second / review monitor, but it would not be a good primary monitor.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Sean Lander
    April 27, 2006 at 12:15 am
    [Tom Ackroyd] “So field reversals should be picked up so long as viewing is done on a (ie any flavour of) TV, not a computer display.”
    Well I’ll accept what your saying but my experience is that I have never seen it on an LCD.
    The production facilities I work at ALL check their final programs on CRTs for this very reason.
    Some have both types of monitors in their suites, generally Plasma is the client monitor and the CRT sits
    next to the editor. OR they have one suite that has a proper Broadcast CRT and they check every
    story on it because all suites are linked with X-San.
    The other issue here is cost. If you want a BROADCAST quality LCD or Plasma it is going to cost you
    quite a lot more than a Broadcast CRT. In Australia, I think the penetration of LCD and Plasma is still
    under 20%. So I would wait. As production ramps up the LCD Plasmas will get significantly cheaper
    in the next year or so.
    my 2 cents
  • Marc Rolph
    April 27, 2006 at 3:27 pm
    I agree with Walter (per usual.) My Panasonic plasma just about rightly matches my Sony broadcast monitor. But, I don’t really turn the plasma on except at the end of a long edit session to see the progress I’ve made, or when I’m showing the final product to the client.
    We’re still in the stage of the big monitors, plasma and/or LCD, are for pomp and circumstance. Getting a traditional CRT broadcast monitor, now multi-format, to do your editing on should be everyone’s choice.
    Marc Rolph
    Producer/Director
  • Ken Summerall
    April 27, 2006 at 3:45 pm
    Thanks for all of your input. It confirmed what I was thinking, but not what I was hoping for.
    I guess a couple of Sony 20″ CRT’s will be the way to go. Anybody want to contribute?
    Thanks Again
    Ken Summerall
