Activity Forums VEGAS Pro Production Assistant rendering clips from events in timeline?
  • Production Assistant rendering clips from events in timeline?
    Posted by Scott Babcock on September 22, 2009 at 6:32 pm
    Hi, I’m playing with Production Assistant and one of the things I’m hoping to accomplish is rendering/exporting my clips/events from the timeline as separate files. Is this possible? I can’t figure out how to do it without it exporting one whole or long file.
    Thanks for the help!
    -Scott Babcock
    CreativePoint Productions
    Scott Babcock replied 17 years ago 4 Members · 11 Replies
  • 11 Replies
  • Theo Van laar
    September 23, 2009 at 9:57 am
    “Have you tried “render selection only”?”
    How would you incorporate this in the action of Assistant? Because Assistant will have to make the selection for every event one by one.
    Theo
  • Adam Rose esq.
    September 23, 2009 at 11:29 am
    even without PA, you could probably use a script to enclose each event within a region, then use the built-in batch render script to render each region as separate file
  • Scott Babcock
    September 23, 2009 at 5:33 pm
    Thanks. Yes, I was wondering if PA could do that instead of using the batch script in Vegas. Seems like it should (thought I saw it in the video on the Sony site with DSE) but now I’m not sure. I’ll have to review, I guess.
    One type of project I frequently work on involves extracting tons of clips from 1-2hr files, placing them in the timeline in sections for a given topic. Then I was thinking I could render out the clips in each section to a folder (windows media is what I want to have in the end), as this is what I need in the end, files for a topic in a their own folder. I have tried selecting the area of the timeline and selecting the individual clips and then processing but it wants to make one file out of all of them. I see in the PA interface that it says ‘process individual files’ so not sure I’m reading that correctly?
    -Scott Babcock
  • Theo Van laar
    September 23, 2009 at 9:06 pm
    ‘I see in the PA interface that it says ‘process individual files’ so not sure I’m reading that correctly?’
    Yes, you read that correct. If you choose in the first tab (source media) to use media files, you can have them rendered to separate files or as one project on the timeline. But when you choose CURRENT PROJECT AS SOURCE, this will be seen by Assistant as only one item.
    Theo
  • Scott Babcock
    September 23, 2009 at 9:26 pm
    So I guess the solution is to maybe use PA to automate creating regions in the timeline – but then it starts rendering the whole timeline so cancel that – and then use the Batch Script to render the regions out to the format and location I want.(?) Unless anyone has a better flow…
    Thanks for your answer.
    -Scott
    -Scott Babcock
  • John Rofrano
    September 24, 2009 at 3:55 am
    Actually, Ultimate S Pro can do this with it’s Render tab. Production Assistant assumes you want to process multiple files in batch mode and is not really set up to render regions interactively.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Scott Babcock
    September 24, 2009 at 2:02 pm
    Thanks, I had UltimateS way back… I don’t know when. (I’m trying to get my info sent to me in email). Looks like it will do what I want and lots more.
    So, is there any reason to use PA over UltimateS Pro? Both made by VASST, right? Wonder why UltimateS Pro wasn’t the offering if it does all and maybe more?
    Thanks for the tip,
    -Scott Babcock
  • Scott Babcock
    September 24, 2009 at 6:58 pm
    John, how would I alter the Windows Media output settings in UltimateS Pro? There’s a 512Kbps then jumps to 3Mbps. I need a 2Mbps. Possible? I don’t see an ‘edit’ button to alter.
    Thanks and I like the app.
    -Scott
    -Scott Babcock
  • John Rofrano
    September 24, 2009 at 7:07 pm
    Yes. Production Assistant is geared toward batch “processing” not just batch rendering. Ultimate S Pro cannot batch “process” (i.e., add FX, crop, add overlays / underlays, etc. automatically as a process list). All of the processing is done interactively with US Pro. Production Assistant can also automate the composition of projects using templates starting outside of Vegas. PA will continue to focus on adding more automation capabilities while US Pro will continue to focus on more interactive editing capabilities.
    ~jr
  • John Rofrano
    September 24, 2009 at 7:24 pm
    Just make a new WMV template under File | Render As… and then close and open Ultimate S Pro and it will pick up the new template.
    ~jr
