Activity › Forums › VEGAS Pro › Production Assistant 1.0
  • Production Assistant 1.0
    Posted by Jason Warfe on September 25, 2014 at 2:36 pm
    Five years or so ago I purchased the VASST Production Assistant. I recently upgraded to a new computer but cannot install the production assistant on the new machine. Any suggestions on how I can get this awesome tool running again?
    Specs for new computer
    1 Case Annihilator
    2 Motherboard MSI X79A-GD45 Motherboard
    3 Processor Intel® Core™ i7-4930K Processor (Choose)
    4 x4 RAM/LD8G1600XPG Memory 32GB – Xidax Performance 1600MHz DDR3 (32GB (4x8GB))
    5 Power Supply Corsair RM1000W Power Supply
    6 B-RAY/BD-RE Optical Drive 14X BD-RW Combo
    7 Graphics EVGA NVIDIA GeForce GTX Titan Black Superclocked – 6GB GDDR5 (Choose)
    8 GPU OC Overclocked Graphics Card – 1 Card
    9 Sound Cards Onboard Audio
    10 HD/DS/2TB-7K HDD/SSD Western Digital Black 2TB (2TB HDD)
    11 HD/DS/2TB-7K 2nd HDD Western Digital Black 2TB – 7200RPM 3.5″ HDD (2TB HDD)
    12 HD/DS/2TB-7K 3rd HDD Western Digital Black 2TB – 7200RPM 3.5″ HDD (2TB HDD)
    13 4th HDD Samsung 840 EVO 1TB SSD (1TB SSD)
    14 RAID Config RAID 0
    15 CPU Paste Premium CPU Thermal Paste – Lower Temps 5-10° C
    16 GPU Paste Standard Graphics Card Thermal Paste
    17 Cooling Xidax 570LX CPU Cooler
    18 OS Windows 8.1 64-bit
    John Rofrano replied 12 years ago 3 Members · 7 Replies
  • 7 Replies
  • John Rofrano
    September 25, 2014 at 8:03 pm
    [Jason Warfe] “Five years or so ago I purchased the VASST Production Assistant. I recently upgraded to a new computer but cannot install the production assistant on the new machine. Any suggestions on how I can get this awesome tool running again? “
    What is the error you are getting?
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Steve Rhoden
    September 26, 2014 at 8:58 am
    You should not have any issues installing and using the latest version!
    But you failed to be specific as to what the problem is…
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Jason Warfe
    September 26, 2014 at 1:34 pm
    Sorry guys, I transferred over all the data files and when I tried to fire up the “PALauncher” I got the message “Vegas Pro Production Assistant installation may be corrupt. Cannot find the Registry entry. Please re-install.”
    That is as far as I can get. Thanks for the help guys.
  • Jason Warfe
    September 26, 2014 at 1:46 pm
    Also, I am getting “Production Assistant requires Vegas Pro. A compatible Vegas Pro installation could not be found. The installer will now close. Your system has not been modified.
  • Steve Rhoden
    September 26, 2014 at 11:30 pm
    Uninstall Production Assistant, Reinstalling Vegas and then reinstall
    Production Assistant…
  • John Rofrano
    September 27, 2014 at 12:45 pm
    [Jason Warfe] “Sorry guys, I transferred over all the data files and when I tried to fire up the “PALauncher” I got the message “Vegas Pro Production Assistant installation may be corrupt. Cannot find the Registry entry. Please re-install.””
    That’s because on Windows (unlike a Mac) you can’t just copy files over and expect programs to work. You must re-install them to re-establish their registry entries. The error is telling you that it can’t find the registry entries that should have been established during the installation process and therefore is recommending that you re-install.
    ~jr
  • John Rofrano
    September 27, 2014 at 12:52 pm
    [Jason Warfe] “Also, I am getting “Production Assistant requires Vegas Pro. A compatible Vegas Pro installation could not be found. The installer will now close. Your system has not been modified.”
    Production Assistant 1.0 is compatible with Vegas Pro 8.0, Vegas Pro 8.1, and Vegas Pro 9.0. Do you have any of those installed on your system? If not, that’s why the installer can’t find a compatible Vegas Pro installation.
    If you want to use Production Assistant with versions of Vegas Pro greater than 9.0 you will need to upgrade to Vegas Pro Production Assistant 2.0 which supports Vegas Pro 10.0 thru 13.0.
    ~jr
