Activity Forums Audio Product Advice for Switching Audio Outputs
  • Product Advice for Switching Audio Outputs
    Posted by Kesten Migdal on January 5, 2012 at 6:16 pm
    I’m constantly reaching in the back of my Mac Pro to switch between headphones and external speakers. I also have different input devices such as a DirecTV box and an audio preamp I use with Logic Pro. Should I just get a few simple 3.5mm male to female extension cables, or are there some sort of switching devices that I can leave on my desk?
    Thanks in advance for your help.
    Craig Alan replied 14 years, 8 months ago 5 Members · 6 Replies
  • John Fishback
    January 5, 2012 at 6:50 pm
    If it’s a fixed position a small patchbay would work. Also, if you Google there are probably switch boxes of various inputs/outputs available. Checkout https://www.Markertek.com.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
  • Kesten Migdal
    January 6, 2012 at 12:01 am
    Excellent, I’ll check out your suggestions. Thanks!
  • Ty Ford
    January 6, 2012 at 3:52 am
    Hello Kesten and welcome to the Cow Audio Forum,
    Why are you switching outputs jacks on the Mac? Why not assign them from the Audio/MIDI panel?
    Now for the inputs.What are you plugging in where?
    Regards,
    Ty Ford
    Cow Audio Forum Leader
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
  • Brian Reynolds
    January 6, 2012 at 7:09 am
    There are several units around for editing systems… one of these might suit your needs.
    https://www.mackie.com/products/bigknob/
    https://www.samsontech.com/samson/products/processors/c-class/ccontrol/
    https://www.behringer.com/EN/Products/MON800.aspx
    The difference between Knowledge and Wisdom is… Knowledge is the knowing of facts…. Wisdom is the sensible application of good quality knowledge…
  • Kesten Migdal
    January 6, 2012 at 8:18 am
    Thanks! I’m going to give the Behringer a try. Price is right at $65.
  • Craig Alan
    January 8, 2012 at 12:46 am
    The mac pro has two headphone out ports (front and back) and an optical digital out port.
    OSX 10.5.8; MacBookPro4,1 Intel Core 2 Duo 2.5 GHz MacPro4,1 2.66GHz 8 core 12gigs of ram. GPU: Nvidia Geoforce GT120 with Vram 512. OS X 10.6.x; Camcorders: Sony Z7U, Canon HV30/40, Sony vx2000/PD170; FCP 6 certified; write professionally for a variety of media; teach video production in L.A.
