Activity › Forums › Adobe Photoshop › Producing RGB and alpha channels like an existing file (attached)
  • Producing RGB and alpha channels like an existing file (attached)
    Posted by Rok Picasso on January 4, 2014 at 1:05 am
    Hi. I’m attaching two PSD files to show what I mean. I want rose.psd to become like tunnel.psd, which has 5 channels including an alpha channel. How do I go about this?
    And if that would save time, is there a video somewhere that I can watch to help me do this? I looked for some reference material on Photoshop channels, but it did not help me understand how tunnel.psd was produced, or how to re-produce the same look in a new file.
    Thanks to anyone taking the time to help and share tips.
    6951_tunnel.psd.zip
    6952_rose.psd.zip
    Rok Picasso replied 12 years, 8 months ago 2 Members · 2 Replies
  • Herbert Van der wegen
    January 8, 2014 at 1:35 am
    1) click (mac: ctrl->command key) on the rose layer thumbnails. This loads the transparency as a selection.
    2) switch to the channels palette
    3) click on the second icon from the left at the bottom of the channel palette. This saves the selection as a channel.
    4a) (optional) to generate a black background, to deselect the active selection, and switch back to the layer palette.
    4b) Add a solid color layer (fourth button from the left bottom of layer palette)
    4c) drag this layer to the bottom underneath the rose layer
    4e) right-mouse click the rose layer (NOT the thumbnail) and choose “Flatten image”.
    That’s it: you now have the same setup as the other image.
    System: Win7 64bit – i7 920@3.6Ghz, p6t Deluxe v1, 48gb (6x8gb RipjawsX), ATI 7970 3gb, EVGA 590 3GB, Revodrive X2 240gb, e-mu 1820. Screens: 2 x Samsung s27a850ds 2560×1440, HP 1920×1200 in portrait mode
  • Rok Picasso
    January 8, 2014 at 4:47 pm
    Thank you very, very much for your explanation, Herbert. Much appreciated.
    I’m a bit new to channels in Photoshop, especially Alpha channels, so will take my time to figure this with your guidelines as soon as I have time, and hopefully will have no further questions. =)
    Thank you again.
