Activity › Forums › Media 100 › Producer looking for Boris Composite Suite filter
  • Producer looking for Boris Composite Suite filter
    Posted by Nick Lammers on June 7, 2007 at 9:15 pm
    Hi. I just started playing with the demo version of Producer. It’s opening my older M100 project files just fine. The only problem is when I try to open an old CG – I get a message saying “could not edit the composition because the boris composite suite filter plugin was not found” and I’m advised to make sure the plugin is installed in the Filters folder. I can’t find the plugin (although I did find a Graffiti 4.0 Filter in the graphics folder). Also, where is this filters folder located?
    Thanks for any help.
    Nick Lammers
    Media Mill, Inc.
    St. Louis, MO
    Media 100i XS 8.2.2
    Dual 1Ghz G4
    Nick Lammers replied 19 years, 3 months ago 2 Members · 9 Replies
  • 9 Replies
  • Floh Peters
    June 8, 2007 at 8:13 am
    What do you mean by “old” CG? From Pre-Graffiti days? Can you create new Graffiti titles?
  • Nick Lammers
    June 8, 2007 at 12:04 pm
    HI Floh. I created the titles using Red 3.0 – sorry I didn’t include that bit of info. Perhaps the fact that they were created in Red instead of Graffiti is causing some difficulty.
    Nick Lammers
    Media Mill, Inc.
    St. Louis, MO
    Media 100i XS 8.2.2
    Dual 1Ghz G4
  • Floh Peters
    June 8, 2007 at 12:05 pm
    Yes. You cannot edit RED titles in Graffiti.
  • Nick Lammers
    June 8, 2007 at 12:10 pm
    Makes sense. I guess if I get Producer Suite with Red included that I will be able to edit the “older” titles.
    Nick Lammers
    Media Mill, Inc.
    St. Louis, MO
    Media 100i XS 8.2.2
    Dual 1Ghz G4
  • Floh Peters
    June 8, 2007 at 12:11 pm
    [nickel] “Makes sense. I guess if I get Producer Suite with Red included that I will be able to edit the “older” titles.”
    Or, if you want to test it, get the Red trial version. You should be able to install it for Producer.
  • Nick Lammers
    June 8, 2007 at 12:12 pm
    I’ll do that. Thanks, Floh, once again.
    Nick Lammers
    Media Mill, Inc.
    St. Louis, MO
    Media 100i XS 8.2.2
    Dual 1Ghz G4
  • Nick Lammers
    June 8, 2007 at 12:36 pm
    Hi again. One last question: if I want to export a self contained file that I can then open in my Media100i, what should my settings be? On the “i” I normally work at 200kb, 4:3, NTSC, 720×486, 7.5 IRE. I tried this yesterday but when I imported the clip it required rendering.
    Nick Lammers
    Media Mill, Inc.
    St. Louis, MO
    Media 100i XS 8.2.2
    Dual 1Ghz G4
  • Floh Peters
    June 8, 2007 at 12:43 pm
    You should “upgrade” to Media 100 i V8.2.3a, which should fix your rendering problem (as long as you work in Media 100 i codec in Producer and you export as self-contained).
  • Nick Lammers
    June 8, 2007 at 12:57 pm
    Thanks. I have 8.2.3a. I’ll go back and take a look at my Producer settings.
    Nick Lammers
    Media Mill, Inc.
    St. Louis, MO
    Media 100i XS 8.2.2
    Dual 1Ghz G4
