Processor fan
Posted by Thayalan Paramasawam on October 12, 2012 at 1:53 amGood morning sir,
My current processor temp is 53·c when rendering project file in vegas 11……so any best processor fan to reduce my temp…..or can i use water cooler for processor.is it safe or any damage to motherboard when using water cooler.pls adivice me on this matter.
Thank you
Thayalan paramasawamThayalan Paramasawam replied 13 years, 11 months ago 4 Members · 7 Replies -
Graham Bernard
October 12, 2012 at 7:40 amFirst off, I’d be looking at what I was rendering to and from what Project settings. No doubt you will have the FX-ing and so on to do what you want, but initially I’d be looking to see if Vegas was having to do too much.
Only after doing an audit of the procedure I was putting Vegas under would I then consider trying to cool the PC down?
Oh yes, and secondly, do inspect the air ways and filters and “Fan filters” if you have. Many, many years ago I had what I thought was an air filter. Only to be told by John Rofrano, when I showed him, that “No Grazie!! You do not have a filter over your fan . . . That’s a collection of rubbish sitting on/over your CPU fan!” – Of course he was correct. So then I carefully brushed and vacuumed out the “filter” – rubbish, and my PC went silent and chilled out.
So, rendering is the most CPU intensive=heat producing process that us editors throw at our PCs. If you have anything that exacerbates the work load, rendering will discover it.
Cheers
Grazie
October 12, 2012 at 2:48 pmHi sir,
What is the best temp for proessor when rendering…….
Matt Crowley
October 12, 2012 at 3:27 pm53C is not very hot for a CPU under load. Vegas will usually keep the CPU loaded to near 100% during render, but you don’t really need to worry unless the temperature gets much above 70C – the safe limit varies between processors I think.
Water cooling or even a better air cooler will help, but your temperature is not high enough to worry about.
Bruce Brent
October 12, 2012 at 6:36 pmThayalan, just for your info, here’s an example of the latest Intel CPU and some of the best rated coolers (air & water).
https://www.legitreviews.com/article/1801/12/
*** Any way of cooling the CPU chip just adds more life to it.
October 12, 2012 at 10:35 pmGood Morning Sir,
Thank You very much sir for the adivice…. (Mr.Graham Bernard,Mr.Matt Crowley and Mr.Bruce Brent)
Thank You
