Activity Forums Adobe After Effects Expressions Processing inverted opacity values
  • Processing inverted opacity values
    Posted by Ryan Daily on September 13, 2017 at 7:25 pm
    I am sad that after 15 years of AE my expression skills are still pretty rudimentary.
    I have an adjustment layer controlling a “lights out” effect. When the opacity of the Lights Out layer is at 0 the effect is basically hidden. When the value is at 60 the room looks dark. Because I want the light sources in the image sequence to stay visible I am only raising the value to 60.
    So what I am in effect trying to do is link the opacity of the Lights Out adjustment layer to the opacity of other layers but in reverse. I want the opacity value of 60 on my adjustment layer to equal 0 as an opacity. I want the opacity value of 0 on my adjustment layer to equal 100 as an opacity.
    This is my sad attempt:
    Thanks for being such a supportive community.
    x= thisComp.layer("LIGHTS OUT").transform.opacity;
    if (x = 60) x=100;
    Dan Ebberts
    replied 9 years ago
    2 Members · 4 Replies
  • Ryan Daily
    September 13, 2017 at 7:57 pm
    I am getting closer but my low value will only go as low as 40 and I want it at 0.
    linear(value, 0, 60, 0, 100)-thisComp.layer("LIGHTS OUT").transform.opacity;
  • Dan Ebberts
    September 13, 2017 at 8:14 pm
    Like this maybe?
    x= thisComp.layer(“LIGHTS OUT”).transform.opacity;
    linear(x,0,60,100,0)
    Dan
  • Ryan Daily
    September 13, 2017 at 8:21 pm
    Nailed it! Thank you so much.
    Do you have a tip jar set up anywhere?
    I think this is like the 4th time in 10 years that you have saved my day.
  • Dan Ebberts
    September 13, 2017 at 8:32 pm
    My site does have a tip jar:
    https://motionscript.com
    Thanks for asking. ☺
    Dan
