Activity Forums Maxon Cinema 4D Procedural textures on Mograph clones
  • Procedural textures on Mograph clones
    Posted by Jason Coursey on May 13, 2008 at 8:24 pm
    Hi, Cow.
    Anyone know how to put procedural textures on clones?
    I know how to use the multishader to put basic colors on clones, but what if you have say, 5 clones and you want to put a custom procedural shader on each one?
    Thanks in advance,
    Jason
    Adam Trachtenberg replied 18 years, 4 months ago 2 Members · 4 Replies
  • Adam Trachtenberg
    May 14, 2008 at 11:43 pm
    You can use procedurals in the multishader just like you would use bitmaps. But the easiest way, if you only have five objects, would be to duplicate your object five times under the cloner and give each one a unique material.
    AdamT
    Cinema 4DXL8 Bodypaint
    *Remember: Tues. is national Shoe Day. Wear shoes to show your support for bimetalism and the designated hitter rule!*
  • Jason Coursey
    May 14, 2008 at 11:49 pm
    Thanks for the response, Adam.
    How do you use procedurals like bitmaps with the multishader? Do the procedurals have to have a specific extension when saved?
    Jason
  • Jason Coursey
    May 14, 2008 at 11:55 pm
    The duplicating worked too, thanks!
  • Adam Trachtenberg
    May 15, 2008 at 4:43 pm
    You just load whatever you want into the multishader’s channels instead of loading a bitmap. Here’s an example: https://www.3danvil.com/tutorials/multishader_prcdrls.c4d
