Activity Forums Maxon Cinema 4D Procedural activation of keyframes of a cloned, rigged character
  • Procedural activation of keyframes of a cloned, rigged character
    Posted by Kelton Bingham on June 2, 2014 at 11:00 am
    Hi, I have a character/joints that I have cloned, using a cloner in object mode, with a plane as the object reference. So basically I have a grid of 3×3 characters/joints. Now what I need is, for the first z axis, rows’ keyframes to activate, then the second and then the last. Normally if I had a cloned OBJECT, I would apply an inheritance effector to the cloner and use a box shaped falloff to activate a column at a time.
    The problem that I am having is that the rigged character has multiple joints, and I can only apply the inheritance effector to one joint at a time. If I use an inheritance effector for each joint, it causes random rotations and positions.
    Any help will be greatly appreciated.
    Regards
    Kelton Bingham replied 12 years, 3 months ago 2 Members · 4 Replies
  • Darby Edelen
    June 3, 2014 at 3:10 am
    This may not achieve what you’re after but you can use an effector to offset the keyframed animation of each clone.
    Darby Edelen
  • Kelton Bingham
    June 3, 2014 at 7:35 am
    Thanks for the reply.
    I have tried using the inheritance effector already, as this gives me correct results with cloned OBJECTS, but I am unsure how to apply it to rigged characters. Applying an inheritance effector to each joint results in random rotations to each row of clones.
    Do you know how to delay keyframes with any other effectors, or how to apply the inheritance effector properly to rigs?
  • Darby Edelen
    June 3, 2014 at 5:08 pm
    [Kelton Bingham] “Do you know how to delay keyframes with any other effectors, or how to apply the inheritance effector properly to rigs?”
    Almost any effector can be used to offset the cloned source’s animation. The notable exceptions are the Target, Spline, Inheritance and Delay effectors.
    Look for the ‘Time Offset’ parameter in the ‘Parameter’ tab of the effector. Based on your description of the setup I’d start by using a Plain effector with a falloff or a Shader effector. The Shader effector would give you a higher degree of control but may take more tweaking to get working properly.
    In cases where the root of the cloned object’s axis is animated you’ll need to disable the ‘Fix Clone’ option on the Cloner or place it inside of a stationary Null.
    Darby Edelen
  • Kelton Bingham
    June 8, 2014 at 7:30 am
    Thanks, works perfectly with the shader effector and a falloff
