Activity Forums Adobe After Effects Problems working with illistrations made in PS
  • Problems working with illistrations made in PS
    Posted by Dane Silzle on September 23, 2005 at 1:38 am
    Hi all,
    I work with an artist that creats illistrations in Photoshop, which I then get in a RGB psd Layer or Layers, to create either a Animatronic or some kinda’ Video flipboard.
    I notice some of his colored-in, illistrations, seem to be reacting heavily with interlace line and look really funky on the NTSC Monitor but not on the Apple DVI display.
    I have tried a number of things:
    1.)Going back to photoshop, adding NTSC broadcast safe color filter.
    2.)Doing the same in After Effect.
    3.)Adding Reduce interlace filter in AE.
    Although they seem to affect it alittle, it’s not enough……
    Please, any experts that have a Color and size format for illistrations (to be used with AE) or other suggestions that will help me with this problem, PleaseHelp !
    Thank you so much !
    Dane Silzle
    drp
    PS I have been revicing my PS files 850X600 150dpi RGB .psd
    System I’m working on:
    Dual 2.5 G5
    1.5GB DDR
    OS 10.3.8
    AE 6.5
    PS 7
    AI CS
    FCPHD
    Todd Morgan replied 21 years ago 2 Members · 1 Reply
  • Todd Morgan
    September 23, 2005 at 10:35 pm
    Go into adjust>levels and lower the output white to 240 or so. You can output to NTSC waveform monitor and see the difference it makes bringing the levels down to braodcast standard.
