Activity Forums Apple Final Cut Pro Legacy Problems with Twixtor in FCP7: 10% slowmo ist freezing every 5 frames
  • Problems with Twixtor in FCP7: 10% slowmo ist freezing every 5 frames
    Posted by Mladen Pavlovic on May 4, 2012 at 9:00 pm
    I have converted an EOS5DMarkII clip with MPEGStreamclip to AppleProRes.
    Then I have import the clip in FCP. The settings for the sequence have been adopted to the settings of the clip. I have followed the tutorial of RE:Vision Effects on how to do slowmotion using the twixtor plugin in FCP.
    In the rendered clip I have the problem, that 5 frames are rendered correctly in 10% slowmo an then 5 still frames are following, than 5 correct ones, and than 5 stills again.
    I have found some posts, whiche are explaining this problem with a framerate issue. But in the FCP twixtor plugin there are no settings for the frame rate. The only thing that I can do is to set the sequence setting same as the clip setting.
    Thanks for any tips.
    Tong Harry replied 13 years, 11 months ago 2 Members · 1 Reply
  • Tong Harry
    September 21, 2012 at 8:36 am
    The same problem,four freeze frames in every 5 frames.
