Activity Forums Adobe After Effects problems with the illustrator files
  • problems with the illustrator files
    Posted by Triki Yassine on March 6, 2010 at 11:05 am
    after effects prensents a probleme when handeling an illustrator file, when using the puppet tool an only when slecting the conserve the file poperty option ( to get read of the pixelisation)the base image turns to a mask kind objet and maks the change appears whith transperency… i have find a solution to the probleme is by turning off the conserve property option but i want to conserve the sharpness of the image
    Michael Szalapski replied 16 years, 6 months ago 2 Members · 1 Reply
  • Michael Szalapski
    March 8, 2010 at 3:03 pm
    You could put your Illustrator file in a large composition with the continuously rasterize switch turned on in that comp. Then import that larger comp into your main comp and apply the puppet pins to it.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
