Activity Forums Adobe After Effects problems with stills only being 1 frame
  • problems with stills only being 1 frame
    Posted by Avril Wallace on August 22, 2006 at 9:26 pm
    Hello, I am having problems when importing a photoshop comp to animate…It is comming in only 1 frame, I have tried changing the duration in the comp settings but it does apply to the files. Please help i was hoping to animate them soon. thanks a bunch.
    Tim Kurkoski replied 20 years, 1 month ago 2 Members · 1 Reply
  • Tim Kurkoski
    August 23, 2006 at 4:31 pm
    When you import your stills, uncheck the “Sequence” option in the Import dialog. AE7 checks this by default if your still image appears to be part of a numbered sequence. But if there’s only one file, it only makes the sequence one frame long.
