Activity Forums Apple Final Cut Pro Legacy problems with some footage
  • problems with some footage
    Posted by Tim Lisandro on January 18, 2008 at 7:05 am
    I finished an edition that contains mp3 audio, jpg, some footages converted as NTSC from a PAL JVC hd camcorder, dv footages and arts from after effect as quick time animation. So I’ve got problems with audio and video’s rendering and exporting to a quicktime dv movie. The pics from JVC appears to be zoom in and the audio started with other in point that I ever chosen and a little bit confuse. Other thing that happened, the arts exported from after effects as quicktime animation, I transformed it into a motion template and when used as a superimpose track and exported as a quicktime DV movie or mpeg 2. they don’t have a linear movement, the movement breaks. The FC I use is the 6.01 version, my macpeo is a quad 3.0 ghz one. is it a bug? or have I made a unknown mistake? So I finished my edition but it was a hard work, cause when I rendered the pics, changed the audios in point, when I fixed it I couldn’t move or render nothing, cause the audio changed again. So after render or move something the audio changed the in point I undid by pressing the command + z and it came back to the correct in point.
    Please if could anyone help me to understand I’ll be grateful.
    Thanks in advance.
    Tim Lisandro replied 18 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
