Activity Forums Avid Media Composer Problems with Project from another Avid
  • Problems with Project from another Avid
    Posted by Satesh Ramjattan on July 12, 2007 at 10:27 pm
    Hello,
    I received a project today from another Avid. I don’t know what kind, info not available. I got their media(from OMFI folder) as well. Now the problem I am having is when I open their project and try to look at it on my client monitor (via Mojo), all I get is either black or some kind of disturbance, wavy what ever. Can’t make out anything. I checked all my settings and all seem fine. The only way I can see anything on my client is if I open the bins with all the footage in another or new project. Does anyone know why this is, why when I open their project I see nothing on output, but see it when opened through another?
    thanks
    Kenton Vannatten replied 19 years, 1 month ago 3 Members · 3 Replies
  • Geraint Pari huws
    July 13, 2007 at 9:29 am
    Their origional project settings maybe creating a problem, especially if they were using older hardware. But if you can see the media then you should be able to work around… check through their project rather than your site/user settings.
  • Geraint Pari huws
    July 13, 2007 at 9:36 am
    If their media appears in the media tool, have a look at stats and check resolution, file type..mxf/omf etc etc, it may have some clues and then come back for nore..
  • Kenton Vannatten
    July 23, 2007 at 2:49 am
    [quote]all I get is either black or some kind of disturbance, wavy what ever[/quote]
    What you’re describing kind of sounds like it you may be viewing PAL footage in an NTSC project, or vice versa. I know that whenever I feed a PAL signal to our Adrenaline in an NTSC project it does just that.
    Kenton VanNatten
    Avid Editor (for hire)
