Activity Forums Maxon Cinema 4D Problems with OBJ Import from XSI
  • Problems with OBJ Import from XSI
    Posted by Karim Daire on February 21, 2014 at 2:35 pm
    I am a Cinema Noob and usually just use basics to get into Element/After Effects to animate/render.
    I got a model that was made in SoftImage, exported to DAE and OBJ and I get very strange results on some parts of the model where shading/reflections are inverse. Its especially strange that this seem to be random elements of the model while the rest is absolutely fine.
    In Element I can fix this by using “Auto Normals” but the object becomes a lot less smooth and quality degrades.
    I checked in Cinema and some of the normals (not all) seem to be inverted. Anyway, when using recalculate/invert normals that does not fix the problem too. I get the same results as in Element when removing the Cinema Phong tag from the meshes… shading is OK but the mesh becomes a lot more edgy.
    We managed to fix this through importing to Blender and recalculating normals there and exporting back to OBJ but I wonder how you can solve this in Cinema directly.
    Does anybody have experienced similar problems with OBJ/DAE files… is the XSI-> Cinema workflow the problem or the exchange formats?
    Thanks for any hints in advance,
    Karim
    -Karim-
    Freelance Cutter, Compositor and Animator from Hamburg/Germany
    Adam Trachtenberg replied 12 years, 7 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    February 21, 2014 at 4:28 pm
    You should be able to fix it in Cinema using the “align normals” command, but if the object also has a normals tag that could mess things up. If it does I would try deleting the normals tag and see how it looks. You may also have to adjust the settings in the phong tag.
