Activity Forums Blackmagic Design Problems with newest Decklink SP drivers
  • Problems with newest Decklink SP drivers
    Posted by Matt Morrison on May 3, 2006 at 5:39 pm
    I’m having problems with the 5.5.1 Drivers for Decklink SP Windows and Premiere Pro 1.5. Any time I add any transition to the timeline I get the “Sorry, a serious error has occured that requires Adobe Premiere Pro so shut down” error message and occasionally all audio output will cease and I have to reboot the system. I’ve tried rolling back to the last set of stable drivers for my system (5.4.2) but I’m still having the problem. The system was stable before and I had a gut feeling to jusst leave it alone, but for some strange reason I felt compelled to update the drivers. I’m using the Decklink DV settings and capturing from a PD-150 if it helps. And I followed all the usual steps for removing and installing the drivers.
    Chris1621 replied 20 years, 4 months ago 6 Members · 22 Replies
  • 22 Replies
  • Matt Morrison
    May 3, 2006 at 6:33 pm
    Well I finally got it to successfully roll back to the 5.4.2 drivers and everything seems stable again.
  • Howpix
    May 4, 2006 at 3:35 pm
    I have also had problems with 5.5 and 5.5.1. When I tried to open the capture module, the computer did a cold boot. Going back to 5.4.2 fixed it. I went to 5.5 because it was supposed to recognize DV machines.
    At first I couldn’t get 5.4.2 to work when I reinstalled it but realized that when I was installing it I was allowing the installation program to retain newer *.dll’s, etc. By asking they be replaced with older files, all was well.
    I don’t see many complaints about this problem so I have assumed it is limited to the DL SP (and possibly other older cards) and that I’m one of the few left using such ancient technology.
    Sometimes it’s easier to work around problems.
  • Kristian Lam
    May 5, 2006 at 12:16 am
    Hi guys,
    We’ll check this out and get back to you as soon as possible.
    regards
    Kristian Lam
    Blackmagic Design
  • Kristian Lam
    May 5, 2006 at 4:38 am
    Hi guys,
    We’ve tried but failed to replicate this issue. Please contact us with more information about your hardware.
    GO to Start > Run and type “msinfo32”.
    Send the resulting file to us at support[at]blackmagic-design.com. Any more details you can provide will also be helpful. Thanks.
    regards
    Kristian Lam
    Blackmagic Design
  • Igor Babic
    May 5, 2006 at 7:22 am
    I have Decklink HD Extreme on 5.5.1 instaled in a machine where was previous drivers 5.4.2 and SD Extreme PCI-X. ( those drivers was uninstalled prior to removing SD Extreme card.)
    I am also heaving same problems with capture in Premeire Pro 2. When I try to capture from YUV input from Betacam SP machine over RS 422 my PC goes to hard reset. It goes to reset in a moment when I press any button on a machine control interface of PPro2 capture or if Betacam machine is in stand by mode as soon comes up PPro resets my PC. After that I have uninstalled drivers, remove any instance of BMD & DeckLink in registry and install all over again 5.5.1. Now system dont reset, but I can’t capture at all, can’t open new project when some project is already open, and can’t change any preferences. When I try one of those things PPro become non responsive. Today I will format C….. (cure for everthing)
  • Kristian Lam
    May 5, 2006 at 8:04 am
    Please also let us know your system configuration, including the make/model of your motherboard. Send use the NFO file you get by going to Start -> Run and typing “msinfo32”.
    regards
    Kristian Lam
    Blackmagic Design
  • Igor Babic
    May 5, 2006 at 11:49 am
    My config is:
    X6DAE G2
    2xXeon3Ghz
    2GB RAM
    PCIE GF6600
    Intel SATA Raid ctrl SRCS28X
    3x250Gb WD RAID0
    Nec FW ctrl
    When I reformat my system I will send you nfo.
    Igor
  • Howpix
    May 5, 2006 at 12:48 pm
    I can’t possibly send a 6MB file through email. Someone’s server will choke.
    MOBO: SuperMicro P4SCT+II
  • Igor Babic
    May 5, 2006 at 1:04 pm
    use zip…
  • Howpix
    May 5, 2006 at 2:00 pm
    Duh! Sorry. Worked (of course).
Page 1 of 3
