Activity Forums VEGAS Pro problems with moving audio events from Canon 5D
  • problems with moving audio events from Canon 5D
    Posted by Grzegorz Kwiatkowski on January 31, 2013 at 12:18 pm
    I am editing 25 minute episodes for TV. I am editing native mov files from two Canons 5D.
    I recorded audio through a field mixer connected to one of Canons 5D (two channels: microport and boom mic), so the video files contain two audio channels (stereo stream).
    When I put the video files on SV12 timeline, everything works fine. But when I split audio channels into two separate tracks, one of the audio events is lagged. It takes 4 seconds to move it after I click it.
    I am doing ten 25 minute long episodes and it’s drives me nuts. Any ideas?
    Grzegorz Kwiatkowski replied 13 years, 7 months ago 3 Members · 7 Replies
  • 7 Replies
  • Steve Rhoden
    January 31, 2013 at 4:12 pm
    Im trying to figure out your issue….What specific procedure you use
    to split the audio channels into two separate tracks?
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-832-4956
  • Bob Peterson
    January 31, 2013 at 4:26 pm
    Don’t split it. Duplicate the stereo audio channel. Then right click the original, click on channels from the pop up menu, then click left channel. Repeat for the duplicate, but select right channel.
  • Grzegorz Kwiatkowski
    February 2, 2013 at 4:24 am
    That’s what I have been doing Bob.
    February 2, 2013 at 4:25 am
    Steve,
    I’ve been doing exactly the same procedure Bob described.
  • Steve Rhoden
    February 2, 2013 at 9:16 am
    ok, mmm, Hard to figure out what could be wrong…. Have you
    tried altering the settings under the Audio Device in
    Preferences to see if things would behave differently?
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • Bob Peterson
    February 2, 2013 at 6:41 pm
    Then I am not sure what you mean by lagged. Duplicating a track does not move it on the time line. If you mean that the computer is not responding when you try to drag the event, then I think the problem is your computer rather than Vegas. It must be doing some swapping to get the resources to perform the function.
    February 2, 2013 at 9:24 pm
    I really don’t know why is it so. Dragging an audio event takes 4 seconds before it moves. If the video event is linked with the audio, it is also lagged. When I ungroup the video, it responds properly. The problem remains in one of the separated audio channels. It slows down workflow very much.
