Activity › Forums › Apple Final Cut Pro Legacy › problems with Motion in FCS3
Posted by Greg Nosaty on October 18, 2009 at 6:06 pmI have reluctantly upgraded to FCS3 and installed the new Kona3 drivers. I had to open a project that was finished last March to edit a new version. When it opened all of the graphics and text like lower thirds were corrupted. The Motion clips in the timeline had linked to different fonts and the geometry had changed.
Is this a bug with the new version? Has anyone else experienced compatibility problems with Motion?
cheers,
Greg NosatyCinemontage Productions Inc
David Roth weiss replied 16 years, 11 months ago 3 Members · 6 Replies -
David Roth weiss
October 18, 2009 at 6:46 pmDid you do a clean install or did you merely put your disks in the optical drive and install over the top of FCS2?
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Greg Nosaty
October 18, 2009 at 7:05 pmOne of each actually. My Quad w/ LHe was a clean install and the 8 core was an overwrite. boths systems experience the same problems with Motion.
cheers,
David Roth weiss
October 18, 2009 at 8:03 pmDid you create a clone of either system? If so, you can boot to that and make your changes in the old environment and then export a QT and use that in the new environment.
David Roth Weiss
Director/Editor
Greg Nosaty
October 18, 2009 at 9:50 pmNo I didn’t make a clone. My assistant assistant is making the mods to the text as needed and re-rendering. It’s just an odd glitch that I wondered if anyone else experienced. But it’s probably just the ghosts in my machines. Not life, or job, threatening.
Thanks David.
cheers,
David Bogie
October 18, 2009 at 9:57 pm[Greg Nosaty] “When it opened all of the graphics and text like lower thirds were corrupted. The Motion clips in the timeline had linked to different fonts and the geometry had changed.
“No to all of the above.
We have had zero trouble opening any of our dozens of Motion templates, some go back to Motion 1, and this is after FCS3 and Leopard (not Snow Leopard).I would immediately assume Kona is at fault but we have never used Kona products.
Editorially:
Making a backup clone of your system before doing an upgrade is simply plain good practice but I am not a supporter of the scorched earth upgrade policy for upgrades and major updates. I just overwrite the new FCP each time a new one comes out. I do the same with each new MacOS. I’ve been doing Mac updates and upgrades for more than 15 years.bogiesan
David Roth weiss
October 18, 2009 at 10:13 pm[david bogie] “but I am not a supporter of the scorched earth upgrade policy for upgrades and major updates. I just overwrite the new FCP each time a new one comes out. “
And I saw a guy on TV fall out of plane without a parachute who lived to tell about it. So, I guess that means nobody needs a chute???
David Roth Weiss
Director/Editor
