Activity Forums Apple Final Cut Pro Problems with Keyframing on export in FCPX
  • Problems with Keyframing on export in FCPX
    Posted by Jim Kehoe on April 13, 2015 at 6:40 pm
    Hey guys,
    I am using Pixelfilm Studios Pro Karaoke in FCPX and am having problems on the export with keyframing the drop zone bounce text. It looks perfect when played back in fcpx but when i export every beginning word does not come in correctly, it’s like theres a keyframe that’s caught or stuck on the render. I attached three screen shots, the one at 8 seconds is the full screen playback in fcpx and the one at 9 seconds is the same but in quicktime as a rendered file. What’s odd is quicktime shows 9 seconds while fcpx shows 8 seconds at the same exact time. I have also attached a screenshot of the session in fcpx (1080p 30fps) Look forward to hearing from someone. And i have been exporting in Pro Res 422 and have tried H.264 and sending to Compressor, no luck at all. Thank you!
    Jim Kehoe replied 11 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
