Activity Forums Adobe Premiere Pro Problems with import interleaved files (Surround)
  • Aanarav Sareen
    October 29, 2006 at 3:48 am
    It appears as if your Scratch Disk has run out of space. Delete the file from your project, empty up the harddrive and then re-import the generated file.
  • Phocas Kroon
    October 29, 2006 at 9:47 am
    Indeed the project pointed to the wrong scratch disk. I changed that to a disc with 60 Gb free space, but the same problem. I found out that I cannot import anymore small clips or audio at all, even in new projects! Maybe I have to reinstall Premi
