Problems with Green Screen – shadow on screen around edges of body
Dear Friends,
Really hoping you can help me. I am working on a project and had to use the clients own green screen. I’ve had two major problems.
After taking footage I have noticed the colours are not even (ie one side of green left to person is going almost gray whilst other side is nice and green). I have got round trying to even colours across but had to play around a whole host of videoFX plugins (including some Boris FX ones) – how do you guys all even out all the green screen colors in these situations?
Second problem is worse…the persons shadow is showing on the green screendirectly outlining one side of the person. Whatever I do, whether I chose choke FX etc…even after removing all the greens, on one edge side of persons body you can see a gray thick outline made by the shadow. Choking effects unfortnately also remove the good edges of the person on their non shadow side.
Appreciate if you have any good ideas and techniques on this?
I am using Sony Vegas 10 (32bit) on Win7 (64bit) with Borix FX version 8.0. I used BCC Chrome key for green screen since it seemed better than Sony Vegas’s native version. I used BCC Composite choker to further cut away still visible greens (due to green screen being uneven color). I was thinking of rendering this and then using BCC Chroma again the second time on the end result to remove the Gray colour shadow outline or using masking techniques but maybe this method would be going too far.
Again, appreciate any assistance.
Rgds
Sandy
