Activity › Forums › Apple Final Cut Pro Legacy › Problems with getting digital mosaic patterns in compressor
  • Problems with getting digital mosaic patterns in compressor
    Posted by Andreas Sweden on November 7, 2006 at 11:44 am
    I have major problem with compressor, when I try to export with the high quality setting using compressor I get a lot of digital disrubance doesn’t matter if it is 60, 90 or 120 min encode. No differens if the sequence contains multiple clips with filters or one long raw clip.
    I get some with the fast encode aswell but not as bad. How do I fix this? Im on FCP 4.5 on a G5 dual 1.8 with 3.5 gb of RAM.
    Is there any other way to do this? Does Cleaner 6 do the job just as well? I am really bad with the different types of compression so I would prefer to just get compressor to work since I don’t have the time or skills to experiment.
    Andreas Sweden replied 19 years, 11 months ago 2 Members · 2 Replies
  • Tom Wolsky
    November 7, 2006 at 11:51 am
    Two=pass VBR was broken in that version of Compressor.
  • Andreas Sweden
    November 7, 2006 at 6:53 pm
    Is there a patch for it? Or can I use Cleaner6 sucessfully?
