Activity › Forums › Adobe Premiere Pro › Problems with External Hard Drives
Posted by Javi Salde on September 13, 2006 at 1:34 amI
Ron Moody replied 20 years ago 4 Members · 5 Replies -
Blast1
September 13, 2006 at 1:53 amYou said you are using Hubs, have you tried daisey chaining the drives.
Blast1
September 13, 2006 at 11:12 amYes, sometimes firewire devices work better if chained, sometimes hubed, you have to experiment, also if you have your cam connected when you are having problems, try disconnect it, is this a laptop or desktop with a onboard firewire?
Aanarav Sareen
September 13, 2006 at 1:55 pmFirewire hubs usually can’t handle drives or anything major for that matter (cameras/tv cards etc.) I would reccomend plugging them directly into your computer or try using a USB port for connecting your drives.
Aanarav Sareen
premiere@asvideoproductions.com -
Ron Moody
September 14, 2006 at 5:51 amNot an authority but XP sometimes misses my external Maxtor 160. Strange, but I’ve noticed that sometimes it takes on a drive letter from another drive on the network that isn’t attached at the moment.
Sometimes the drive doesn’t show up at all.
On occasion I yank the USB cable in from the printer and plug it into the Maxtor, XP wakes up and sees the drive.
Yes, two separate behaviors, equally strange. I’ve never queried the Windows XP knowledgebase. I guess I just figure that as long as I can fool XP into seeing the drive when I need it to, I’ll just let it go.
ron
