Activity Forums Adobe Premiere Pro Problems with encoding
  • Problems with encoding
    Posted by Michael Forsberg on June 10, 2013 at 1:45 pm
    I was given video clips (MPEG4) off of an old Evo phone from my stepdaughter to make a DVD out of using Premiere Pro Cs6. I brought them in Premiere with no special presets letting Premiere make all of the adjustments. I finished the project and imported it into Encore. I finished the menus etc. and was ready to build the DVD. When I went to transcode, it would transcode in about 25 minutes of the project then hang. I tried encoding with AME, but it get into 25 minutes of the project then stops or hangs. Not sure what to do. There are not gaps or spaces in the timeline. Any help would be appreciated. Thanks in advance. Michael
    Michael
    Chris Tompkins replied 13 years, 2 months ago 2 Members · 1 Reply
  • Chris Tompkins
    June 10, 2013 at 2:10 pm
    Sending your finished edited sequence from Pr to Encore is the way to go.
    Did you select the DVD mpeg2 preset?
    You can have a corrupted file. Check the clip at the 25 min. mark. Maybe, step out of premiere, transcode that one file with AME, bring the new file into Pr and replace.
    Chris
