Activity Forums Apple Final Cut Pro Legacy problems with dissolves
  • problems with dissolves
    Posted by Mekael Adu on October 18, 2010 at 11:10 am
    Hi again !!
    I’m still having this issue with rendering dissolve on my timeline, FCP is putting a flash frame or video glitch when adding a rendered cross dissolve.
    the footage has been converted from VOB to H.264 mov using mpeg-streamclip …is this the correct codec to use ?.
    the video seems to playback fine but when a dissolve is applied the glitch happens during the transition.
    it also happens when i overlay the clips and do a opacity dissolve with the pen tool after rendering.
    Any Helps Please !!
    Mekael
    Mekael Adu replied 15 years, 11 months ago 2 Members · 2 Replies
  • Zane Barker
    October 18, 2010 at 4:03 pm
    [Mekael Adu] “footage has been converted from VOB to H.264 mov using mpeg-streamclip …is this the correct codec to use “
    Nope. NEVER edit h.264 it is a delivery codec. Convert the footage to one of the formats listed on the easy setup list.
    **Hindsight is always 1080p**
  • Mekael Adu
    October 18, 2010 at 7:01 pm
    Thanks Zane !!
    I done a bit of reasearch all saying the same thing as you, so I’m going to convert them from VOB into Quick time.mov using a Apple Dv codec. i hope this will cure the problem.
    I tried to convert VOB straight to DV using mpeg streamclip but FCP has to render on the timeline to hear the Audio. Any ideas why ?
    Watch my post, i’m sure I’ll have loads of Silly questions to ask over the next couple of months
    Thanks again !!
    Mek
    Mekael
