problems with compression and transcoding
I have my DVD set up exactly how I want it, but it says I’ve used 6.4GB on a 4.7GB disk. I can drop one thing, but it says I’ve used 4.9GB, so it’s still bigger than the disk I have. How can you compress it to be used on the 4.7GB disk? (I understand that the video quality will suffer)
I tried to transcode a single file and it said that I needed to either use the larger disk setting or take something out of the project. I decided to just test out the build, so I set the disk to the 8.4GB setting and tried to transcode again and it came up with an error that says I have one chance to save (but don’t save as the same file name).
Please help. Thanks in advance.
