Activity Forums VEGAS Pro Problems with capturing clips from camcoder
  • Problems with capturing clips from camcoder
    Posted by Dimitri Chapov on August 21, 2009 at 10:15 pm
    Hi folks:
    Please advise.
    I’m capturing video clips from Panasonic tape camcoder into Sony Vegas Pro 9. Viseo is fine. Audio is fine only in the capture Window on playback. There’ sno sound in Vegas’s clip editor or SoundForge to that matter. Is something wrong with my codecs or something? How come I can hear sound in Capture window then?
    Thanks.
    Dimitri Chapov replied 17 years, 1 month ago 2 Members · 7 Replies
  • 7 Replies
  • Theo Van laar
    August 24, 2009 at 2:49 pm
    Was the audio recorded as 12bit or 16bit?
    Theo
  • Dimitri Chapov
    August 24, 2009 at 2:58 pm
    12 bit. I thought about that. There’s no way to convert it on Panasonic NV-GS230 as I understand. I found a “workaround” – captured the tape with Microsoft Windows Movie Maker and then used in the Vegas editor. Would quality be higher if I could have done it in Vegas? Also, what affects the quality of the captured video, besides the camcorder itself – fire-up vs USB, type of capturing software, computer hardware?
    I’m sorry if my questions are naive – I’m just playing around with that for the first few days. And I am not an expert in Video/Audio compression either. 🙁
    Dimitri
  • Theo Van laar
    August 24, 2009 at 4:18 pm
    Do you mean that you can not record audio with your Panasonic NV-GS230 in 16bit mode??? Most likely that would solve your problem.
    Theo
  • Dimitri Chapov
    August 24, 2009 at 4:38 pm
    Yes, I can. But I already have over three hours of recorded footage in 12 bit. There’s no way I can re-sample on such an inexpensive camera. For some reasons there’s nothing I can do with the *.avi odtained by the capturing through Vegas – SoundForge just doesn show any sound in it, even though File Properties dialog tells there is, and I can play audio with video in Sony Capture 6 normally.
    Movies Maker doesn’t complain about capturing at all and everything works afterwards – both video and audio.
    Generally, if there’s no difference in capturing quality, I can live with that. If there is – I am going to record video with 16 bits sound encoding NEXT time. But I was thinking about salvaging those three hours of footage. Nothing important but, you know, of sentimental value – family life shootings, my wife, son and I, you know.
    I just hate the very idea that I don’t have understanding and control over that technical crap.
    Theo, thank you so much for you time! What do you think affects quality of *.avi on the computer:
    1/ USB vs Fire-Up Cable
    2/ Algorithm (Vegas vs Movies Maker)
    3/ Computer hardware
    Thanks a bunch. I really appreciate your advice.
  • Theo Van laar
    August 24, 2009 at 4:57 pm
    ‘What do you think affects quality of *.avi on the computer’
    If you are talking about DV-avi: capturing means nothing else as copying, so without loss. However, as soon as you render (i.e. recalculate the video or audio) you loose quality.
    Theo
  • Dimitri Chapov
    August 24, 2009 at 5:10 pm
    So, if my picture is not like that on Discovery Channel when I render off DV quality (“as is”, up to 178Mb per minute of footage) it means Panasonic is a shitty camcorder for $600 (in Moscow, Russia, two years ago) and I need something for $5,000-6,000 to make clips like National Geographic? I mean, their DVDs show great picture on my computer – I want the same. I don’t mind having lighting problems, you know, I just want to have that “crisp”.
  • Dimitri Chapov
    August 26, 2009 at 3:31 pm
    Now I have another one… With DVD Architect this time:
    Refuses to burn a DVD, saying that:
    ‘SFMMCX’-(17)
    “-(2)
    -‘TSSTcorp CDDVDW TS-H653N HB02’-(0)
    Module
    f:\source\sonic3\release\dvdarchitect\5.0\cddrvs\sfcd\sfmmcx.cpp Line 1869 (sounds like a line in C++ code on a drive I don’t even have)
    A hardware error occured.
    Unknown Additional Sense 08 03
    Status 00020202
    (+plus some hex memory dump)
    What can I do?
