Activity Forums Blackmagic Design Problems with Blackmagic Intensity Shuttle USB 3.0
  • Problems with Blackmagic Intensity Shuttle USB 3.0
    Posted by Furor Des wahnsinns on April 18, 2012 at 5:23 pm
    Hello =)
    At the first sry for my bad english 😉 i am from Germany and i dont find any german Support Hotline ore Forum for Blackmagic Products =(
    I Have buyed the Intensity Shuttle USB 3.0… The Problem is it dont work with my Asus P8H67-I… It uses not a NEC USB Chip it use a Asmedia Chip… Its a Mini-ITX Board and i dont have any free PCI Slot in my Computer… Have anyone a Idea how i can use my Intensity Shuttle USB 3.0 With my Mainboard? ore must i realy buy a new mainboard? =(
    Greets Akio
    Jr Bergstraten replied 14 years, 3 months ago 2 Members · 1 Reply
  • Jr Bergstraten
    June 7, 2012 at 6:16 am
    See if you can check out the firmware from the Asmedia chipset.
    110230 works. You can check it with u.bat (Google it).
    I have also an Asmedia 1042 and it doesn’t work (yet).
    Hopefully a firmware update of yours works but be VERY VERY careful with that as you can’t go back, unless the ITX board manufacturer gives it to you.
