Activity › Forums › Adobe After Effects › problems with black solids
  • problems with black solids
    Posted by Patryk Rebisz on July 4, 2007 at 5:24 pm
    i’m applying Knoll Lighting effect (lens flare) to black solid. The lens takes its position from a null of a tracked object. If i apply the Knoll effect to the footage layer all is fine but when i apply the effect to black solid — it does some wird stuff — it looks like the flare is attached to something of screen… ANyone knows what’s going on?
    Patryk Rebisz replied 19 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    July 4, 2007 at 8:04 pm
    The effect expects the light source coordinates to be relative to its own layer’s upper-left corner.
    This expression should do the translation for you:
    L = thisComp.layer(“Null 1”);
    fromWorld(L.toWorld(L.anchorPoint))
    Dan
  • Patryk Rebisz
    July 5, 2007 at 4:08 am
    You tha man!
